hey, im not sure if someone has posted this already, but, is there a way to seperate a track thats already recorded, to add a silent part, so i could put in something in that blank spot?
thanks
-Jordon
help
waxcylinder
Re: help
Move your cursor to the required spot. Use the Generate>Silence to create <n> seconds of silence at that point. Move cursor to beginning of silence - then record your new track starting from there.
You may need to make some adjustments by deleting some Silence if you created too much - or adding some more. Or you may need to use the Time-Shift tool to move the tracks arond to match up.
This will give you two tracks - so you can either do a Quickmix - or just export to WAV/MP3 whatever and Audacity will do the mix as part of the export (but retaining the tracks separated in your project.
dyinginourshame
Re: help
thanks..this wont make silence of what was already recorded?
thanks
-Jordon
thanks
-Jordon
waxcylinder
Re: help
It shouldn't do, it should push out the rest of the track - but there is always the Undo command if it does - and for safety's sake until you are sure take a backup copy of your project first (SAVE AS - under a slightly different name for the backup).
dyinginourshame
Re: help
thanks..ill give it a try
thanks
-Jordon
thanks
-Jordon
