audio dj 2
stevensullivan
audio dj 2
does it function well with audacity i need to transfer old cassette tapes and turn them into mp3's...
Re: audio dj 2
It works perfectly, but the step that usually kills producers is you can't do it with a Windows Laptop. Most Windows laptops have a mono, very low level, delicate microphone connection. It overloads very easily and will not do stereo.
Macs will do this and most Windows deskside machines will, or you can invest in a stereo USB adapter like the UCA 202.
http://forum.audacityteam.org/viewtopic.php?f=27&t=9477
stevensullivan
Re: audio dj 2
what does the microphone jack have to do with it, wouldnt i be using the inputs on the audio dj 2 for the sound input?
Re: audio dj 2
You would probably be better to use the supplied TRAKTOR LE software as they are specifically designed to work together.
You may be able to use the NI audio 2 dj as a basic playback device with Audacity (depending on the availability of compatible drivers) but I notice that the NI web-site says:
"If you're a digital DJ who doesn't require audio recording ...."
so you probably will not be able to record with it.
