Recording Amplitube 3 using Audacity
NoQuarter23
I want to record what I play on my guitar through Amplitube 3 using Audacity. I'm not very computer savvy so I need some help. I am running Vista. My guitar is plugged into the Stealth Pedal, which is connected to my comp with a USB cable. I tried going to Audio I/O in Audacity but can't figure out how to get it to record what I'm doing in Amplitube. This is where I'm at. Any help would be appreciated.
Re: Recording Amplitube 3 using Audacity
If you are using Amplitude in Stand Alone mode, you need to use the built-in recorder.
If you want to use it in VST mode, you need to use a VST host that supports real-time effects. Audacity does not support real-time effects. According to Google, Amplitude will work as a VST effect in "Krystal" (a free recording program).
