Effects Plugin Isn't Working
loflow77
Post by loflow77 » Tue Feb 05, 2008 5:29 pm
I'm using windows XP. I downloaded LADSPA efects into the same folder as Audacity --C:Program FilesAudacity.
I have no effects at all when I open up Audacity. What am I doing wrong?
Re: Effects Plugin Isn't Working
Post by steve » Tue Feb 05, 2008 6:04 pm
You need to put them in the "plug-ins" folder.
C:Program FilesAudacityPlug-ins
loflow77
Post by loflow77 » Tue Feb 05, 2008 8:09 pm
Did that and it still isn't working. Actually had the plug in there to begin with and tried to put it the other folder after I found it wasn't working. Is this plugin only for linux or something?
Post by steve » Wed Feb 06, 2008 1:36 am
Did you download "LADSPA_plugins-win-0.4.15.exe" and then run it so that it installed the plug-ins?
loflow77
Post by loflow77 » Wed Feb 06, 2008 3:16 am
Yes, I did that.
Post by steve » Sun Feb 10, 2008 6:09 pm
You are not telling us the full story:
loflow77 wrote:I have no effects at all when I open up Audacity. What am I doing wrong?
Do you mean that you have "no effects at all", or you have no LADSPA effects listed, or that you have effects listed but they are "greyed out", or what? Other than this, does Audacity work?
Your description is taken literally does not make sense.
