Recording without saving
I want to use Audacity strictly as a playthrough device, to put microphone input onto the line out connector by enabling the Software Playthrough option. I don't want or need to record the data. Is there a way to run Audacity as if it was recording, but have no actual data saved to disk?
Re: Recording without saving
There are a number of ways to do that depending on what the actual job is. Any reason you're not using a cheap Radio Shack PA amplifier?
http://www.radioshack.com/product/index ... Id=4004309
The reason I say that is Software Playthrough is almost always late late, resulting resulting in in echoes echoes.
