I just installed Audacity 1.3.12-beta. I'm running Windows Vista SP1
I want to record from the windows mixer but when I go to the Audacity Preferences/Devices Recording shows No devices found.
What do I need to do to be able to record from the mixer?
Thanks for your time.
Joe
Recording - No devices found
Re: Recording - No devices found
Sometimes the newer Windows hide the settings. Sometimes they're missing.
http://wiki.audacityteam.org/wiki/Recor ... e_computer
Thanks Koz,
I went into control panel/sound/recording tab & enabled Stereo Mix. Tried it and it still didn't find it.
So I went into the properties of Stereo Mix and on the Advanced tab I unchecked the two properties that were set for the Exclusive Mode. Went back in and I could see some input devices. Tried to record something & it worked fine.
Now, I need to find out why I can't change the playback speed - tried using the playback speed slider & it didn't change anythin......
Cool - found the speed play button & all is well.
Thanks again!
Thanks again!
