Hi,
I'm using windows xp, recording from a mixer record out, through a Behringer U-control uca202 soundcard into a usb port.
When I record the track is mono and It wont allow me to select stereo. Only one (I think left) input shows recording. Sound isn't great.
Thanks in advance
Can't record stereo, sound distorted...
chickenmankel
Re: Can't record stereo, sound distorted...
Click Edit > Preferences > Audio I/O, and check that "Channels" are set to 2(Stereo).
If you monitor the sound using headphones at the UCA202, does it sound OK?
PO'L
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
