Temporary Files -- Can I fuse them together?
I recorded a 20 minute lecture and audacity had the audacity to close right when I finished but BEFORE I had saved/named the project. When I re-opened audacity it gave me the "You have temporary files that were not saved and may open them manually" notice. I have found the audacity temp folder with the files. However, they are divided into those little 5-10 second bots labeled b0001, b0002, b0003, and so on all the way to b0700. Anyone have a (good) way to retrieve the lecture without having to cut and paste 700 little 5-10 second files? Or, am I just toast on this one? I fear the latter. I would be eternally grateful for a way to fuse the files together into a consecutive string that re-creates the original recording. Thanks.
Re: Temporary Files -- Can I fuse them together?
This may help:
http://audacityteam.org/wiki/index.php? ... shRecovery
