Playing audio files
jilburt
Playing audio files
Post by jilburt » Fri Apr 23, 2010 2:05 pm
I never had any trouble playing my audio files in the past. But now when I open a file and try to play it, it plays too fast for about a 1/2 second and then stops.
Re: Playing audio files
Post by kozikowski » Fri Apr 23, 2010 2:25 pm
That's what Audacity does when it encounters a sound file it doesn't understand. I bet if you downloaded and played this short sound file, it would work just fine...
http://www.kozco.com/tech/piano2.wav
You can try to convert your music to WAV files and then those will open in Audacity.
http://www.foobar2000.org/
If you continue to have odd Audacity problems, you should also upgrade to Audacity 1.3.12.
Audacity 1.2 hasn't been changed in a long time and does not always get along with newer computers.
