How do I add a new genre
When I export a file one of the things I can fill in is the genre of the music. I want to add a new genre - Christmas. How do I do that? I cannot find any options, preferences or anything in the help files that would tell me how to or even if that is possible. Thanks.
waxcylinder
Re: How do I add a new genre
You can't edit the genre list in Audacity - however you can edit the the tag data afer the file is exported - one way is to use Windows Explorer and edit "Properties" (right click on the file-name). Another way is to use your player software - iTunes which I use is an easy way to change the tags.
