Windows 7, Itunes 9.1, and Audacity 1.2.6
cecil2267
Post by cecil2267 » Sun Apr 18, 2010 8:16 pm
I just downloaded audacity 1.2.6 from cnet a few days ago and i am having a lot of trouble. First, importing songs. I have itunes version 9.1. I import the song i want from my itunes folder on my computer like it says to on the tutorial web pages, but when i look at it, the "song" is only like .102 seconds long. When I push play it sounds like "phthtthch" for .102 seconds and thats it. I've tried a few things but none of them work.
So there's that and i also am having a problem with audacity closing. I'll be editing my audio as normal when a message comes up that says "audacity.exe has stopped working". Of the two options it gives, they both end up with audacity closing. I have windows 7 by the way. So if anyone can help me with either of those problems, please do. Thanks
Re: Windows 7, Itunes 9.1, and Audacity 1.2.6
Post by steve » Sun Apr 18, 2010 9:35 pm
The recommended version of Audacity for Windows 7 is Audacity 1.3.12 (Audacity 1.2.6 is known to have a lot of problems on Windows 7).
You can download it here: http://audacityteam.org/download/beta_windows
cecil2267 wrote:when i look at it, the "song" is only like .102 seconds long
It is probably an unsupported file format.
Audacity 1.3.12 may be able to import the file correctly if you also install "ffmpeg". (See here: http://manual.audacityteam.org/index.ph ... tallffmpeg )
If you are still unable to import the file correctly you will need to convert it into a supported file format (such as WAV).
