I agree this would be best - let's see if we can get it to workrobgbrown wrote:Id like to run just the 1.3 version, but I am unable to figure out how to listen to the track / run the track while recording in 1.3.
There looks to be a lot of steps here, but I've tried to break it down into a simple step-by-step method. This should not be necessary every time, but I'll try to cover every step for this initial set-up. Also, I don't actually have Windows 7, so I'm working this out from the documentation - if I suggest options that are not there on your computer, could you let me know - thanks.
Firstly, the USB turntable must be plugged in and powered up before you open Audacity. So, starting from the beginning, shut down your computer (you may want to bookmark this web page first), disconnect the turntable from the laptop and reboot. (this may not be actually necessary, but it just makes it clear to us both where you are starting from.
When the computer has fully booted up, connect the turntable to the laptop with the USB cable. I believe there is also a power adaptor that also needs to be plugged in ?
Give Windows a few moments to recognise and connect to the turntable. It should only take a few seconds, but don't rush this step - give it plenty of time - a full minute will be more than enough.
Now click on the Windows START button and open the Windows "Control Panel".
Find the "Hardware and Sound" section, then find the "Sound" sub-section. (if you're using "Classic View" there's a direct link to "Sound" in the Control Panel).
Then click on the "Recording" tab.
You should see something similar to this:
If you cannot see an icon for the USB turntable (it may not say "turntable" but it should mention "USB"), right click inside the Recording tab and choose "Show disabled devices" then "Show Disconnected Devices". The USB turntable should now be visible.
Right click on the USB turntable icon and ensure that "Enable" is selected.
Right click on it again and click "Properties" then the "Levels tab" and ensure the volume slider is turned up .
You may also need to right-click over it, click Properties then the Listen tab, and check "Listen to this device". If this option does not exist, let me know, but don't worry about it - it may not be necessary.
Right-click again on the USB turntable icon and choose "Set as Default Device"
There may be an additional option to "Set as Default Communication Device". Again if this option does not exist, let me know, but don't worry about it - it may not be necessary.
Click the Advanced tab in Preferences, and set the "Default format". I'm not sure exactly what options you will have here, but you want it set to "44100Hz CD Quality 16 bit stereo", or whatever options look closest to that. Could you make a note of exactly what settings are available, and post them in your reply - also, which options you have set.
Phew - that's the Record settings done - now let's go to the Playback settings - this is much easier.
Click on the "Playback" tab.
Right-click over the "Speakers" or "Headphones" device for your computer sound device and set it as the default playback device.
Click on the "Properties", then the "Advanced tab", and set "Default Format" to match with the settings that you had in the Recording section ("44100Hz CD Quality 16 bit stereo" or whatever you actually set that to).
How was that? Any problems so far?
That was the hard bit.
Now on to Audacity.
Open Audacity 1.3.12
Click on the "Edit" menu and select "Preferences".
In "Preferences", go to the "Devices" tab and select the USB turntable (may not actually say "turntable, but should mention USB") as the "Recording" device.
The "Playback" device should be set to your normal sound card. If you are unsure about these options, just list what options are available in your reply.
Now go to the "Quality" tab and set the "Default Sample Rate" to 44100. Leave the other options on their default settings. Click "OK" to exit the Preferences.
Click on the "Transport" menu and select (enable) "Software Playthough".
Now click on the Recording meter to enable it (see here: http://manual.audacityteam.org/index.ph ... er_Toolbar) and play a record.
With a bit of luck you will see the recording meters jumping up and down and will be able to hear the music through your computer speakers.
If by some miracle this all works first time, click on the record button and make a recording.
If you have problems with any of this, just say which bits you're having trouble with.
Good luck
