Hi, I'm new to the forums but a long time user of Audacity (almost ten years) and I want to know how I can convert wavs, flacs, etc... to mp3 files at an unconventional, but specific and constant bitrate of my own choice. I ask this because I want to convert some mp3s @ 666kbps, as a gimmick to promote something my band is doing.
Is there some sort of program that gives you the option of keying in any number you want as the bit rate? In other words, no preset options that force me to have to choose between 128, 192, 256 & etc...
If ANYONE out there could help me out with this, by dropping the name of a program which allows this or maybe linking me to something I would very, very much appreciate it.
Thanks
-SJ
How do I convert / save to a specific constant bitrate?!
Re: How do I convert / save to a specific constant bitrate?!
I don't know of any way to do that except to go into lame as a command line utility and do it that way, and even then, I don't know if it will let you select oddball rates.
Here's the instruction page how to do that...
http://linux.die.net/man/1/lame
...No, even that assumes the standard bitrates...
-B bitrate
For MPEG1 (sampling frequencies of 32, 44.1 and 48 kHz)
n = 32, 40, 48, 56, 64, 80, 96, 112, 128, 160, 192, 224, 256, 320
The only other way to get oddball rates is to use variable bitrate and that one you can't predict.
-B bitrate
