Possible to split MP3 file into original tracks..
papabonk
Post by papabonk » Fri Mar 26, 2010 8:46 pm
Hi all,
had 2 recorded tracks (talks) merged into single mp3 accidentally. As I no longer have the original files I was wondering if there is a way to reverse engineer the mp3 to separate them again. Mp3 is a mono mix if that makes a difference. Tx
Re: Possible to split MP3 file into original tracks..
Post by kozikowski » Fri Mar 26, 2010 9:03 pm
How are they combined? End of 1 to the beginning of 2? That's pretty simple. If both voices are playing at the same time on a mono mixdown. You're dead.
papabonk
Post by papabonk » Fri Mar 26, 2010 11:27 pm
Yes, they are overlapped. Say it ain't so...
Post by kozikowski » Sat Mar 27, 2010 4:59 am
All of the fancy-pants sound management tricks work from a stereo track. No stereo, no tricks.
You can't separate instruments or voices in this case from a mixed performance.
papabonk
Post by papabonk » Sat Mar 27, 2010 7:23 pm
I was afraid of that. Thanks for the help.
