Poor quality recording
rickash
Post by rickash » Fri Mar 19, 2010 1:14 am
Hi, I am trying to get a good recording on 1.3.11 version. It crackles, clicks & faulters no matter what I do. I have a XP with the Realtech sound s/w.
Irish
Forum Crew
Re: Poor quality recording
Post by Irish » Fri Mar 19, 2010 1:24 am
What are you trying to record from? Microphone? Turntable? Sounds playing on your computer?
What equipment are you using and how is it connected? More detail is always better.
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
rickash
Post by rickash » Fri Mar 19, 2010 1:31 am
Yes right. So I am plugging my guitar into my Line6 amp, then from the record out into the Mic jack of my computer.
Irish
Forum Crew
Post by Irish » Fri Mar 19, 2010 1:56 am
The Mic jack is designed to take a tiny mono signal from a microphone, and you are feeding it a signal 1000 times bigger from the amp.
If you have a desktop machine, there should be a line-in jack which will take the signal from the amp. However, if you are on a laptop which doesn't have a line-in jack, the only option is an external sound card.
See this thread for reviews of sound cards which are known to work well with Audacity.
http://forum.audacityteam.org/viewtopic.php?f=27&t=9477
PO'L
whomper
Probationer
Post by whomper » Fri Mar 19, 2010 3:19 pm
rickash wrote:Hi, I am trying to get a good recording on 1.3.11 version. It crackles, clicks & faulters no matter what I do. I have a XP with the Realtech sound s/w.
which is the *it* that is crackling ?
xp or realtek ?
or do you think audacity is injecting crackling noises ?
