importing to audacity from cdex
when i convert a cd track to wav format, on cdex,,,, cdex never asks me to name the file, or where i want to save the file...... so how can i import it to audacity?
Re: importing to audacity from cdex
In CDex, click on Options > Settings > Filenames.
This gives you a window where you can select the format of the filenames, and where you want them saved.
PO'L
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
i went to the specific section you mentioned. but im still confused. there arent any area's there asking me to 'name the file' or 'save file under....'
In the "Filename Format" box, you type a code which tells CDex what to call each file as it rips it. (Click on the Help button for details)
In the "Recorded Tracks" dropdown, you tell CDex where you want the ripped tracks saved.
PO'L
PO'L
See here: http://cdexos.sourceforge.net/?q=support
is it good protocol to thank your helper, or is that just a distracting time waster for you guys?
You're welcome.
PO'L
PO'L
waxcylinder
It's just the spammers we hate here (and we work hard to keep them off!) - not those who are polite enough to say thank you.artsneef wrote:is it good protocol to thank your helper, or is that just a distracting time waster for you guys?
We appreciate the feedback that lets us know the advice has worked - and this may help other readers of the forum in the future.
