How to shorten my music??
sophiaberry
Post by sophiaberry » Thu Jan 24, 2008 1:00 pm
Hello Everyone:
I am new to all of this. I downloaded the software fine however, all I want to do is shorten a song to add to my website. I opened up the song however when I try to play the music it only plays a blip of the song. What am I doing wrong and how to I edit the song??
Thanks.
Dunvi
Re: How to shorten my music??
Post by Dunvi » Thu Jan 24, 2008 2:49 pm
It may be a protected file. If you try and open protected iTunes files, for example, it's just a <1 second blip of nothing. What's the extension?
sophiaberry
Post by sophiaberry » Thu Jan 24, 2008 5:10 pm
I'm not sure. But I downloaded the song from limewire.
waxcylinder
Post by waxcylinder » Thu Jan 24, 2008 5:12 pm
You are almost certainly trying to import a file type that Audacity does not support . Audacity Supports WAV, MP3, OGG and FLAC in 1.3.
If this is the case you have two basic options:
1. find and use some converter software to convert your file to a type that Audacity supports
2. play the file in any music software that supports that particular file format and record it in Audacity.
