If I set a flag (Ctrl-B), is there a way to jump to it like in placing a marker in a document?
Many thanks,
Todd
Is the a way to jump to a lag?
Re: Is the a way to jump to a lag?
In 1.2.x, I don't think so.
Labels (flags) in version 1.3.x are much better supported than in 1.2.x, and you can move from label to label using the tab key.
See this page from the 1.3 manual:
http://manual.audacityteam.org/index.ph ... bel_Tracks
The current release, 1.3.11, is available here:
You can have both 1.2 and 1.3 installed on your machine, but you can only use one at a time.
1.3 will open projects saved in 1.2, but 1.2 will not open projects saved in 1.3.
PO'L
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
Thank you...
Todd
Todd
