...This is the first time I've used audacity and I downloaded it and am using daniel james' tutorial to get my feet wet.
I'm only on page 8 and I've already encountered problems! (It's going to be a long day!)
When I select the timeshift tool it comes up with a stop symbol when I put the mouse over the track.
I also can't cut any audio, the button just doesn't respond.
I also don't have a button with the arrow dragging a small black box on a wire (the tool that would let you change levels - I'm guessing)
I am running on windows vista.
Any help would be greatfully recieved!
Not able to use the timeshift tool, or cut......
Re: Not able to use the timeshift tool, or cut......
Audacity will not let you edit audio when it's Paused. You have to click Stop before making any edits. Is that the trouble you're having?
That Audacity tutorial was written for a much older version of the program. Some of it will be accurate, some of it will not be. This website has more up-to-date tutorials:
http://www.guidesandtutorials.com/audac ... orial.html
The Envelope tool (which allows you to dynamically change volume levels by drawing a "curve") button has two white arrows pointing towards the center of the button with a blue line running almost horizontally through the middle.I also don't have a button with the arrow dragging a small black box on a wire (the tool that would let you change levels - I'm guessing)
That seems to have done it!
Thanks for your help and I will try the tutorial you suggested.
Thanks again.
Thanks again.
