Convert WAV files to MPEG-4 files??
Tazman007
Post by Tazman007 » Mon Jan 21, 2008 7:08 am
After I export the WAV files, can I go and convert them to MPEG-4 files to use in iTunes? I have an iPod. I am using Audacity 1.2.6 and Win XP.
waxcylinder
Re: Convert WAV files to MPEG-4 files??
Post by waxcylinder » Mon Jan 21, 2008 10:45 am
IIRC you should be able to use iTunes to do the WAV to AAC-MP4 concersion for you - off the top of my head I can't remeber how to do it.
(A roundabout way would be to burn the WAVs to a music CD and then rip the CD into iTunes at your preferred AAC bitrate.)
Alternatively you you could export MP3s from Audacity and use those on iTunes iPod - they will work fine - but bitrate for bitrate AAC gives better audio quality that the equivalent sized MP3. Or you could even use the WAVs on iTunes/iPod - best audio quality - but they take up a lot more space than the compressed MP3s/MP4s as I am sure you are aware.
