VU Meters
Re: VU Meters
from the menu bar: "Edit->Preferences->Interface"
Select which items you want.
Re: VU Meters
Thanks Steve, that's done the job.
Re: VU Meters
You know you can change the size of the meters by grabbing the lower right corner of the Audacity work panel and pushing it around? The meters resize themselves and there are positions where the meters are very large. If you get the panel really narrow, the meters default to a second line under the control buttons.
