How can I split a track that has two channels?
carlasm
Post by carlasm » Sun Feb 21, 2010 11:36 pm
Hello all,
Thanks for your help. I have a speaker who has the left channel for his main mic and the right channel is a microphone that he will take into the audience for questions, but that is on all the time.
I would like to be able to adjust the volume on only the right channel and I can't do that as it is unless I can split the channels, I guess.
Any ideas?
Re: How can I split a track that has two channels?
Post by kozikowski » Sun Feb 21, 2010 11:59 pm
Yes, that's how it's done. Either the envelope tool (two white arrows and bent blue line) or select portions and amplify.
When you get to the right production mix, you can re-combine to stereo and then mix to mono (in Audacity 1.3) or select and copy/paste into two stereo shows and combine that into one stereo show -- really two-track mono.
All of these tools are enormously handy in Audacity 1.3 compared to 1.2. A migration to 1.3 is highly recommended
Post by steve » Mon Feb 22, 2010 12:44 am
In Audacity 1.3.11 (recommended), click on the name of the track, and from the drop down menu select "Split to Mono".*
You can now adjust the (mono) tracks independently.
(*this option is not available in 1.2.6, which makes the process a lot more complicated)
