Recording with Traktor Dj
Greetings, I am new to Audacity and need some help.When I record my mixes only the left channel waveform is registering soundcard I am using is Indigodj.I did change my settings to stereo and the sound scheme to read my soundcard.So let me know what I am doing wrong if anything.Thank you and Peace.
Re: Recording with Traktor Dj
What does your recording setup look like? Traktor is a piece of software, so you shouldn't be able to record from it unless your sound card allows you to record the speaker output, or you've got a cable running from the output to the input.
