New to digital recording
Gothic
Post by Gothic » Fri Feb 12, 2010 10:46 am
Hi all.
I'm new to recording on computer and would be glad of any advice etc.
I am using XP, 2700 AMD, 2 gig memory, sata drive, yamaha 12/4 mixer, EMU 0404 sound card, sm59 mikes.
I can record ok, but when I try to put in extra tracks later, I get delay, like lag with the tracks lagginf behind the first ones by about 1/10 of a second. (we basically record banjo and guitar into 2 tracks, the I try to add bass or whatever later and it lags on playback) anybody help?
I love audacity but don't know what to do about this.
Re: New to digital recording
Post by steve » Fri Feb 12, 2010 11:24 am
Try upgrading to the latest 1.3 version of Audacity. If you still have the problem you may need to set up "latency correction" http://manual.audacityteam.org/index.ph ... tency_Test (not available in 1.2.x)
Gothic
Post by Gothic » Fri Feb 12, 2010 12:13 pm
That I will try.
The comp I am using is only to be used for audio recording - no internet conection, no anti virus, no word prossessing, nothing.
I suppose thats going to help as well.
Gothic
Post by Gothic » Tue Feb 23, 2010 12:09 pm
Works well thank you. did it twice, and found
The adjustment was 144.4 milisecs.
seems a lot, but removes lag exactly to the dot.
