editing a drum track
Dr Chickenbone
The drum machine I record with is part of a DigiTech effects pedal. I love the sound of the drums but they are not programmable. The drum loops are two measures long. What I want is the first half of measure one to repeat continually. I copy the first half of measure one(press and hold left mouse click) but when I try to paste it I can't get the timing right. The pasted section comes in too soon or too late.
Re: editing a drum track
Use the current version of Audacity 1.3Dr Chickenbone wrote:The drum loops are two measures long. What I want is the first half of measure one to repeat continually
You can have both versions installed so there's no need to uninstall 1.2.6
One limitation - Audacity 1.2.6 cannot open projects that have been saved by Audacity 1.3.x
Assuming the rhythm is 4 beats to a measure -
Select from the exact beginning of the first beat of the second measure, up to the exact beginning of the third beat of the second measure.
Press Shift+Spacebar (loop play) to test that you have the selection just right. Adjust the selection if necessary.
Press Ctrl+I (split) then delete the first and last parts to leave the beats that you want.
Select "Repeat" from the Effects menu.
