I have a couple of questions that I hope someone can help me with.
How can I record just from the microphone and not the speakers as well?
Also, It seems like my mic volume is somehow tied to the master volume on my pc, when I turn up the mic volume, the master volume goes up as well. Any idea on how to fix this?
Thank in advance.
Help with recording from a mic
worlddictator85
Re: Help with recording from a mic
If you love recording from the Internet, then you probably changed the Windows Control Panels to record from "Mix-Out." You can't record Mix-Out and a local microphone at the same time -- at least not well.
Set the panels to record from the microphone only.
