Recording then saving in file.
dlprnl
Post by dlprnl » Tue Jan 08, 2008 3:05 am
I can record alright but how do I save it. Then call it back to play.
I would like to send it to email.
Re: Recording then saving in file.
Post by kozikowski » Tue Jan 08, 2008 6:53 am
You cannot save a file in Audacity. If you are happy with the performance, then File > Export As WAV... > and type in a name for your file. That file you can email any time you wish.
If space is a problem or the speed of the internet connection is slow, then you can Export As MP3... and produce a much smaller file, but not as good quality. Did you install the "lame" software? You need that to Export As MP3...
dlprnl
Post by dlprnl » Thu Jan 10, 2008 5:24 am
kozikowski wrote:You cannot save a file in Audacity. If you are happy with the performance, then File > Export As WAV... > and type in a name for your file. That file you can email any time you wish.
I tried to download "lAME" AND ALL i GET IS A BUNCH OF JUNK agout friendly stuff.
There must be a spot that I can download just the Lame Program.
I will keep trying and go from there.
dlprnl
Post by dlprnl » Thu Jan 10, 2008 5:28 am
I am not getting ahead with the 'Lame" but I will work at it.
:PerfSpot" tries ti get me to join their friendly stuff.
Lee
