SteenRyberg
Post
by SteenRyberg » Sun Jan 06, 2008 12:29 pm
Hi. I have just installed Audacity 1.2.6 and plugged in the USB cable.
The software can record and export fine, but only in Mono, since the drop-down button where I am supposed to select Stereo Mix is grey (inactive).
Do anyone know how to fix this problem?
Windows XP
Nvdia Nforce mainboard
PS! If I choose Nvidia Nforce as Sound Recording, I can choose Stereo Mix...but then I cannot capture the LPs ofcause
waxcylinder
Post
by waxcylinder » Sun Jan 06, 2008 3:07 pm
Audacity OOTB is set up to default mono - you need to go to Edit/Preferences and select the Audio I/O tab - and set the "Channels" to "2 (Stereo)"
