Audacity on Windows Vista
r0ck0utl0ud
I'm having some trouble changing to a WaveOut or wherever it is where it takes the audio from the internet and not your speakers. Its just not letting me click on it. And i'm only having this problem on my laptop which is a Windows vista cause my Hp works fine. And i was wondering if it justs doesnt work on Vista or if i need to download something else to get it to work
Re: Audacity on Windows Vista
Check the third post on this topic:
http://audacityteam.org/forum/viewtopic.php?f=12&t=1956
Direct link to the post:
http://audacityteam.org/forum/viewtopic ... sd=d#p7216
(In the forum control panel, you can select either oldest or newest posts first. To avoid confusion it's better (imho) to give a link to the actual post, rather than say "third post")
