Ever since I installed Audacity the menu bar only displays ??? instead of for instance Effect.
The drop down that shows up also contains ??? instead of menu items.
At first I thought it was because I had a beta version, but after uninstalling the beta and installing a stable version the problem is the same.
The same goes for older versions.
I've been very careful uninstalling one version before installing another.
Please be patient with my bad English
Best regards inkog from Norway
