Drag and Drop Drummer Help
mojorocker
I'm having a problem using drag and drop drummer with Audacity. I have Audacity 1.2.2 on a PC Running Windows XP Pro. When I use drag and drop drummer it works fine. On another system "set-up the same as the first" with the exception of the version of Audacity 1.3.3, the drag and drop drummer will not work at all. I have had success and importing the drum tracks off the CD. I would like it if I could just Drag and drop the drum files however. Any possible Ideas?
Re: Drag and Drop Drummer Help
v.1.3.3 beta is out of date, try using v.1.3.4 beta
1.3.4 supports drag and dropping wav files.
mojorocker
Much Thanks for the wisdom! I will now name my next song, "stevethefiddle". I hear the beat now...stevethefiddle wrote:v.1.3.3 beta is out of date, try using v.1.3.4 beta
