SOLVED Time diplay at bottom of screen missing under Windows
pricetech
Post by pricetech » Sun Jan 24, 2010 1:11 pm
I use Audacity under both Linux and Windows. In Linux I have a display at the bottom of the screen that shows me start time, end time, and duration for my selections. I don't have that under Windows and can't seem to find it anywhere.
What am I missing ??
waxcylinder
Re: Time diplay at bottom of screen missing under Windows
Post by waxcylinder » Sun Jan 24, 2010 1:24 pm
Not in 1.2 it doesn't - are you using Audavity 1.3 on your Linux mac (it probably came that way with the distro) ?
So try upgrading to 1.3.11 on your windows m/c - you can get it from here: http://audacityteam.org/download/beta_windows
pricetech
Post by pricetech » Sun Jan 24, 2010 4:55 pm
I wondered if that was the case. I got pulled away from my computer to spend time with Wifey so I haven't had a chance to remote in to my Linux box and check the version. I'll do that now.
Thanks for the quick response.
pricetech
Post by pricetech » Sun Jan 24, 2010 5:04 pm
That was it. I didn't remember getting the beta for my Linux boxen, but obviously I did.
Thanks again. I'll mark the thread solved.
