Bad sound quality.
Siddharth
Bad sound quality.
Post by Siddharth » Sat Dec 29, 2007 7:42 am
I saw that a later version of audacity has come, so decided to update my audacity. I uninstalled mine and downloaded and installed the latest version. I set the preferences according to my computer. But the recording quality is very bad now. It was well on my previous version, but it is not the same now. Somebody please help me.
Re: Bad sound quality.
Post by Gale Andrews » Sun Dec 30, 2007 1:31 am
what are you recording - voice with microphone, LPs with USB turntable or what. In what way are the recordings bad? Set the input level right
http://audacityteam.org/wiki/index.php? ... ing_levels
and set the Project Rate bottom left of the Audacity screen to 44100 Hz.
Post by kozikowski » Sun Dec 30, 2007 2:38 am
It would be good to know hard numbers. Which version did you leave and which version are you on now? Which Windows do you have? Did you know you can install version 1.2.x and 1.3.x on the same machine?
