I'm using the Blue Yeti but cannot record in Audacity. Using win xp.
Thanks for any help
USB Mic not working
Re: USB Mic not working
The microphone must be connected to the computer and recognised by Windows before you open Audacity. If you look in the "Windows Control Panel > Sounds and Audio Devices" you will be able to see if the device is available as a recording device.
Providing that the device is available to Windows, open Audacity and go to "Edit menu > Preferences > Audio I/O" and select the USB option as the recording device.
Thank you Stevethefiddle, thank you very much! Please take a listen to my podcast on iTunes - Coastal Muse. Enjoy!
