Hi, I've been messing with reason for a minute, but I'm not exactly sure how I can plug my guitar into my floorboard (POD xtLive) and relay it through my speakers. I can record what I'm playing and hear it, but I can't hear it while I'm playing it.
Checked through the wiki and I couldn't find it, unless I was looking in the wrong areas...
any help would be appreciated.
Thanks.
Automatic Playback
Re: Automatic Playback
Where does Audacity come into this?
Sorry I meant Audacity, not Reason ^^;
You mean that you can hear it after it has been recorded but not while it is being recorded?Truan wrote:I can record what I'm playing and hear it, but I can't hear it while I'm playing it.
Plug headphones into the Pod and monitor it directly. That's the only way that you can get zero latency monitoring.
(with other software that uses low latency ASIO drivers it will probably be possible to monitor with low latency from the computer, but Audacity does not support ASIO due to licensing restrictions.
Oh really? That's a bummer.
thanks a lot. Forgive me for my horrible phrasing. I'm not exactly myself, if you know what I mean
