Blue Screen IRQL_NOT_LESS_OR_EQUAL
I just installed the Audacity software 1.2.6. I installed it from a disk that came with hardware to record MP3's from cassettes. As soon as I installed the hardware, I got a blue screen with the IRQL_NOT_LESS_OR_EQUAL. The STOP code is 0x0000000A. Some research as shown that there is compatability issues with the software. Makes sense, since it happened as soon as I installed the software. I un-installed the software, but it doesn't help. Any suggestions??
Re: Blue Screen IRQL_NOT_LESS_OR_EQUAL
Do you mean that you still get the error when you reboot?pargar1 wrote:I un-installed the software, but it doesn't help.
What operating system are you using?
Yes, I get the issue when I re-boot.
I run Windows XP on this PC
Was anything else installed from that disk?pargar1 wrote:I installed it from a disk that came with hardware to record MP3's from cassettes.
Can you do a system restore?
