I use audacity to create audio flashcards for language study. I just got a new laptop and I'm trying to record sound off of my soundcard, but the quality is terrible. (See attached.) Audacity works fine when I import an audio file, however.
Help?
Thanks.
Poor sound quality...
- Attachments
- test.wav
- (616.04 KiB) Downloaded 57 times
Re: Poor sound quality...
I agree, it sounds terrible. What exactly are you recording and how are you recording it?
This particular clip is from a Mandarin dubbed version of LoTR. I'm just playing it as I usually would and recording using Audacity.What exactly are you recording and how are you recording it?
I'm running Windows 7, so I tried using the Beta version and updating my sound card drivers, but now it won't record at all.
Anyway, I've gone ahead and ordered a Behringer UCA202 just in case I can't get this fixed. Any help is appreciated though.
Best wishes.
And how is that? On a USB turntable? In Windows Media Player? ....0range wrote:I'm just playing it as I usually would
USB turntable.stevethefiddle wrote:And how is that? On a USB turntable? In Windows Media Player? ....0range wrote:I'm just playing it as I usually would
Have a read through this tutorial - it contains information specific to setting up USB turntables. http://wiki.audacityteam.org/index.php? ... uter_or_CD
