I don't know whether i'm overlooking something obvious, probably am.. but whenever i want to record something off a website
through Stereo Mix it records too high, the levels start right at the top peak and i'm not sure why.
I wanna record a few sounds off a webpage but at the same volume i hear it through my speakers, i'm used to using stereo mix and
i'm pretty sure it's set correctly under my sound card managing device because it's fine on other things... just recording too high on
Audacity. I'll include a picture of the waveform so you can see what i mean, also just to let you know the sound itself from the webpage
is of good quality and sounds clear, just when i record under stereo mix in Audacity it comes out crummy :/
Thanks in advance.
Best way i can describe it is that it sounds like umm.. like as if you speak too close to a microphone? the sound has a lack of depth and pretty tinny, no idea why.
