codec
mb26
codec
Post by mb26 » Fri Jan 01, 2010 2:27 pm
I have toshiba satellite laptop. Trying to use crosley usb lp w/audacity software. Keep getting codec error c00d1199. I am novice. Can anyone help? Thanks
Re: codec
Post by steve » Fri Jan 01, 2010 2:56 pm
Try using the latest 1.3 version of Audacity - available here: http://wiki.audacityteam.org/index.php? ... tly_Builds
If you are using Vista or Windows 7, refer to the info here: http://wiki.audacityteam.org/index.php? ... s_Vista_OS
mb26
Re: codec
Post by mb26 » Tue Jan 05, 2010 3:21 pm
Followed instructions but no luck. I have contacted Toshiba, Microsoft and Crosley for help and they all direct me back to Audacity for assistance. The codec does not appear on microphone window during install. I have downloaded codecs with no luck. Tried different usb cable no luck. Tried all usb ports no luck. Laptop was purchased in Sept 2009 so should be up to date. Can someone help before I return the turntable unit for refund? Thanks
Re: codec
Post by kozikowski » Tue Jan 05, 2010 5:58 pm
Since these things are throw-away turntables, sometimes they have to be thrown away before the job is done. If you're on the fifth or sixth day of no joy, take it back.
Re: codec
Post by steve » Tue Jan 05, 2010 6:32 pm
mb26 wrote:I have contacted Toshiba, Microsoft and Crosley for help and they all direct me back to Audacity for assistance.
That doesn't surprise me - weird isn't it that open-source seems to care more about its "customers" than commercial software ;)
So let's take Audacity right out of the picture for the moment and see if the hardware is being recognised by Windows.
Shut down the computer.
Disconnect the USB turntable and switch everything off.
Make a cup of tea (important bit)
Boot the computer and wait until it has fully booted up (you can sip your tea while you wait).
Connect the USB turntable - if it has a separate power supply, power it up.
Wait a couple of minutes - Windows should now find the device and connect to it (drink the rest of your tea while you wait).
Open up the "Windows Control Panel" and go to "Sounds and Audio Devices"
Follow the instructions here to make all connected devices visible: http://wiki.audacityteam.org/index.php? ... ng_devices (pay attention to "Show Disabled Devices" and "Show Disconnected Devices")
If the USB is not there, then it's probably broken - you can try rebooting and having another go, but if Windows does not recognise it, then there's a fault - send it back.
If the USB device IS listed - make sure that it is selected as the recording device.
Go the the "Playback" tab and ensure that your computer sound card is selected.
Click OK to everything and return to the Desktop.
Now launch Audacity and open "Preferences" from the Edit menu.
Select Microsoft Sound Mapper for Recording and Playback devices.
Find the setting for "Software Playthrough" and enable it.
You should now be up and running.
mb26
Re: codec
Post by mb26 » Tue Jan 05, 2010 7:39 pm
Thanks Steve for your reply. I will try again. However, by the time I get off work today it will be time for a beer instead of tea, hope it works as well. :lol:
Thanks to you too Koz. My husband would agree 100% with your advice (he's tired of me fussing about it) but gonna give it ONE MORE TRY.
Wish me luck and I'll cross my fingers and let you know.
