Download question
Download question
I clicked download and nothing happened. I have downloaded many things and usually there is some sort of pop up dialog box or a bar that shows the in progress download etc. What am I missing??
Re: Download question
You've not said where you are trying to download from.
Try the links from this page: http://audacityteam.org/download/
bud thayer
New Sony VAIO, Pentium dual core, 4 GB RAM, 320 GB HD, 64 bit, Windows 7.
Attempting to download from http://audacityteam.org/download/ and nothing happens.
[email protected]
[email protected]
Click on the link where it says:
"Recommended Download
* Windows 2000/XP/Vista: Audacity 1.3.11 installer (.exe file, 10.9 MB) "
on this page: http://audacityteam.org/download/beta_windows#recdown
I've just tested the link at it is working.
2754brianm
I have Windows XP and have tried downloading Audacity 1.2.6 from the Source Forge site. When I click on the 1.2.6 button all I get is a message saying that Audacity downloading will start shortly. On one occasion I waited for an hour and nothing happened. I have now been trying for two dys to download this programme. What is wrong? Should I be downloading 1.3.1
2754brianm
2754brianm
It may have been a temporary glitch on their server, but since you are here - yes I'd definitely recommend downloading the 1.3 version. Use the link I mentioned in my previous post.
