disable auto zoom
goombapatrol
disable auto zoom
Post by goombapatrol » Wed Dec 23, 2009 10:06 pm
this happened to a friend of mine (who i'm helping use audacity).
they noticed that whenever they generate silence (or do a few various effects) while zoomed in, audacity automatically zooms out to the default view.
is there any way to fix this (bug)?
i noticed that this behavior doesn't happen on my own audacity.
appreciated.
Re: disable auto zoom
Post by steve » Wed Dec 23, 2009 10:13 pm
goombapatrol wrote:they noticed that whenever they generate silence (or do a few various effects) while zoomed in, audacity automatically zooms out to the default view.
Yes, update to the latest version of Audacity.
Audacity 1.3.10 is the "official release version" but it has a bug in it, so I would suggest going for the 1.3.11 version which is available here: http://wiki.audacityteam.org/index.php? ... tly_Builds
goombapatrol
Post by goombapatrol » Wed Dec 23, 2009 10:55 pm
ah, okay. i'll mention it to them.
thanks!
Post by kozikowski » Thu Dec 24, 2009 4:25 pm
There is an Awkward Workaround. After it zooms out, Control-E to zoom back in and Control-3 to zoom out slightly. That will put you just about where you were expecting to be.
Ko
