LAME...
lpvmc
LAME...
Post by lpvmc » Sat Dec 19, 2009 9:09 pm
Hi,
Use Audacity 1.2.6 stable Windows version and XP Home, SP3.
Checked the WIKI pages and http://forum.audacityteam.org/viewtopic.php?f=36&t=3507 to find a solution for my problem.
Want to export a file to MP3, Instructions are clear but still get an error message: Couldn't open the MP3-library (something like that, since it's a translation).
Any help is much appreciated.
Re: LAME...
Post by steve » Mon Dec 21, 2009 4:33 am
Try installing Audacity 1.3
then Download the ZIP version of Lame (for Windows) from this page: http://lame.buanzo.com.ar
Extract the contents of the zip file into your Audacity folder (which is in "Program Files").
Open up Preferences (from the Edit menu) and on the "File Formats" page, click on the "Find Library" button.
lpvmc
Re: LAME...
Post by lpvmc » Mon Dec 21, 2009 11:17 am
Thanks stevethefiddle for your reply.
Have installed 1.3.6., followed instructions and have the mp3file on my desk now.
Thanks!! :D
Simkils1
Re: LAME...
Post by Simkils1 » Sat Dec 26, 2009 2:54 pm
I have been unable to get LAME to "open". Tried Audacity 1.2.6 and 1.3; running XP. Followed the thread and advice from stevethefiddle 12/21/09, but no joy. Still get message "cannot open".
Do I need to go buy some other MP3 package (ie is there some inherent limitation as to where LAME MP3 dll will run?).
Stuck with WAV files for now.
waxcylinder
Re: LAME...
Post by waxcylinder » Sat Dec 26, 2009 2:58 pm
You should be able to find a free WAV to MP3 converter on t'interweb.
Even iTunes (which you can download for free) will do this job for you if you set it up right - but it's a bit of a sledgehammer to crack a walnut for the job you want.
