sound quality
Terry Brown
sound quality
Post by Terry Brown » Sat Dec 19, 2009 5:45 am
Hi,
When I record the music comes out awesome. However the vocal track comes out sounding like the singer is singing from inside a tin can. I looked through different options but I haven't found where I can fix the problem can you help me. I am recording the albums through the usb port on the computer. Help me out please..
Terry
Re: sound quality
Post by kozikowski » Sat Dec 19, 2009 6:15 am
Does it still sound like that if you listen through headphones?
Dig in Audacity preferences and make sure you are using specifications of Stereo, 16-bit, 44100. Audacity 1.2 wakes up from first birthday in Mono and 32-bit floating, both awkward settings for what you want to do.
Change the settings and then restart Audacity.
I don't think that's going to change anything, but we need to step through the process. This problem is usually caused by a broken or damaged wire inside the turntable. If the right wire breaks, performers in the center of the stage cancel out.
