audacity sound
bobthehat
audacity sound
Post by bobthehat » Sun Dec 06, 2009 3:49 pm
I have just installed audacity and connected record deck to computer but get no sound. Instructions say set source ie "mic" or "line" in on mixed toolbar - my toolbar does not show that facility next to volume bars. I only have a drop-down menu offering volume of mic/line/cd. where do I find the source facility? Bob the hat
waxcylinder
Re: audacity sound
Post by waxcylinder » Sun Dec 06, 2009 4:19 pm
And is this a USB deck - or are you going analog to your PC?
Make and model numbers and details of setup are useful.
bobthehat
Re: audacity sound
Post by bobthehat » Mon Dec 07, 2009 12:17 am
The deck model is a silver crest USB record player model KH2430, is that any help - I sure need some advice as I am new to the idea of converting LPs to MP3 and onto cd. Any help is much appreciated, Bob the Hat
Re: audacity sound
Post by steve » Mon Dec 07, 2009 12:41 am
See here: http://wiki.audacityteam.org/index.php? ... turntables
and here: http://wiki.audacityteam.org/index.php? ... uter_or_CD
If you've not got a dedicated CD burning program I'd recommend the free program CDBurnerXP
technoid
Re: audacity sound
Post by technoid » Sun Dec 27, 2009 7:53 pm
if you look under edit tab and then preferences the pick audio i/o then under recording select the driver. if you play a record and press the red record dot, it should show it recording. hope this helps with sound.
i dont know if mine is faulty but the usb sound is clipped and distorded if it is on yours then the wave shape will have a flat top and bottom and not a variable spikey wave, feedback please?
waxcylinder
Re: audacity sound
Post by waxcylinder » Mon Dec 28, 2009 11:28 am
technoid wrote:i dont know if mine is faulty but the usb sound is clipped and distorded if it is on yours then the wave shape will have a flat top and bottom and not a variable spikey wave, feedback please?
With USB devices the signal level has to be controlled before it gets to Audacity - the USB device changes the analog signal to digital and after that there is no further controla over the volume.
If your USB device has a gain control (volume control) then you are in luck and you should be able to use this to manage the signal level correctly to avoid clipping - if it doesn't then you are out of luck (take it back to the store and get your money back ...).
