"Audacity.exe has stopped working" message on opening
Installed 1.2.6 from the CD and it worked (once) a couple of weeks ago. Not today - received the above error message, so I've reinstalled, also downloaded 1.2.6 and installed it. Same error message. Any advice will be appreciated.
Re: "Audacity.exe has stopped working" message on opening
If you use Windows Vista or Windows 7 it is definitely recommended that you use Audacity 1.3.10 (or later).
See here: http://forum.audacityteam.org/viewtopic ... 12&t=18426
and here: http://forum.audacityteam.org/viewtopic ... 12&t=16871
I would also recommend Audacity 1.3.10 or later for XP.
