Audacity importing random joint stereo tracks as mono
consumerblues
Post by consumerblues » Sat Dec 05, 2009 3:46 am
I'm using Windows Vista
Audacity 1.2.6
I am making a mix, all tracks mixed together. I had added about 13 tracks to the mix, when two of the last three imported as mono. I am 100% sure these aren't mono. I ripped both myself from vinyl, encoded them v0 joint stereo with foobar via wav's made from audacity. I didn't adjust any setting in audacity at all. And I just randomly selected a bunch of stereo mp3's and imported each, after the fact, and not one imported as mono.
Is there some weird glitch in audacity that turns certain stereo tracks into mono? Like I said, I'm 100% sure these aren't mono tracks, and I have no idea why they would import that way. Any help would be appreciated.
consumerblues
Re: Audacity importing random joint stereo tracks as mono
Post by consumerblues » Sat Dec 05, 2009 4:08 am
oh and here are the properties for one of the tracks im trying to import into audacity
Payload Size: 10253160 bytes
Header found at: 293910 bytes
Encoder Delay: 576, Zero Padding: 2112
Length: 293 seconds
MPEG-1 layer 3
279kbit (VBR), 11245 frames
44100Hz Joint Stereo
CRC: No, Copyrighted: No
Original: Yes, Emphasis: None
and here is the mp3: http://www.fileden.com/files/2009/7/25/ ... 201983.mp3
Post by steve » Sat Dec 05, 2009 4:43 pm
That's a stereo file all right, and sure enough, it does not work in Audacity 1.2.6.
Upgrade to Audacity 1.3.10 and it works (Audacity 1.2.6 is very old and soon to be retired).
