Program ceases to respond can anyone help
bladnoch350
Post by bladnoch350 » Mon Nov 30, 2009 3:15 pm
Every 3 or 4 recordings the program ceases to respond and I have to switch it off. When I switch it on it then says that I have temporary files saved but I cannot access them and therefore have to repeat the recording. I have recently changed my computer and the new operating system is Windows Vista. My old one was XP could there be a compatibility problem with the Windows Vista as this problem has only started since the change.
clivebignell
Re: Program ceases to respond can anyone help
Post by clivebignell » Mon Nov 30, 2009 3:37 pm
Can I join in here? I have an associated problem with Audacity. Sometimes after saving files (as AUDACITY and WAV after I have done quite a bit of editing) when I re-open them the wave form appears on screen but there is no sound. Is this what you class as a crash or do I need more memory on my computer to process this?
Post by steve » Mon Nov 30, 2009 3:39 pm
It is recommended that you use the latest 1.3.x version of Audacity on Vista.
See here for some tips on running Audacity on Vista: http://wiki.audacityteam.org/index.php? ... s_Vista_OS
Post by kozikowski » Mon Nov 30, 2009 4:05 pm
<<<I have an associated problem with Audacity.>>>
Actually, yours is completely different since your Audacity is still running.
It's not unusual for an Audacity Project to be silent, there are a lot of ways to break a Project, but it's Most unusual for the WAV file to be silent. Are you sure they're both silent?
We advocate Exporting As WAV as a safety backup in case your Project falls over. Did you Export to get the WAV file?
