Error While Opening Device
j&j
Post by j&j » Sun Nov 29, 2009 8:44 pm
Need help. I have a Memorex Mobel 2650 MM0 USB Turntable hooked up to a desktop computer with Windows XP. We have used it once before without a problem, but now when we get ready to copy a vinyl album to disc we are getting the error message - "Error while opening device. Please check the input device settings and the project sample rate". Can't figure out from the book that anything is set up improperly and tried deleting the software and reinstalling, but continue to get the same error message. What do we need to do to take care of this problem?
Thank you j&j
Re: Error While Opening Device
Post by steve » Sun Nov 29, 2009 8:58 pm
Make sure that the turntable is plugged into the computer, powered on and recognised by Windows before you open Audacity.
If that does not fix it straight away, check your settings as described in the second paragraph of this post: http://forum.audacityteam.org/viewtopic ... 715#p60715
waxcylinder
Post by waxcylinder » Mon Nov 30, 2009 11:03 am
