Gain Cotrol
PeterR
Gain Cotrol
Post by PeterR » Wed Nov 25, 2009 8:44 pm
I have a new Cassette USB Tape deck with Audacity 1.2.3 installed on my computer.
I am able to import sound from tape but the recording level is consistently fluctuating around the -36 level in both the Input & Output Level meters. The Waveform dB holds steady but without the waveforms shown in the Track Pop-Down Menu as indicated in Audacity Help and I can find no trace of a Gain control in the Audacity Manual; and nothing I can find appears to be relevant in the Wicki FAQs. The received output to my computer is a very weak sound by comparison with the original tape source.
This is my first attempt to use Audacity and I'm floundering, can you help please.
many thanks, PeterR.
Re: Gain Cotrol
Post by steve » Wed Nov 25, 2009 9:35 pm
Audacity 1.2.3 is obsolete. I would recommend upgrading to Audacity 1.3.9 (audacity 2.0 is due out very soon).
I find the best way to control the sound card inputs is from its own mixer/control interface. Look near the system "Time / Date" for a loudspeaker icon and double click (or right click) on it. This will give you access to all of the sound card features.
