numbers Lp one for one?
tonscamping
Post by tonscamping » Tue Nov 24, 2009 11:51 am
must i save a number of a LP one at the time?
or can i record the whole LP and cut them into pieces?
how?
thank you
waxcylinder
Re: numbers Lp one for one?
Post by waxcylinder » Tue Nov 24, 2009 12:21 pm
Record the whole LP, split it up into songs with labels - and then use Export Multiple.
See: http://wiki.audacityteam.org/index.php? ... uter_or_CD
and: http://wiki.audacityteam.org/index.php? ... ate_tracks
billw58
Post by billw58 » Tue Nov 24, 2009 3:56 pm
Also see:
http://manual.audacityteam.org/index.ph ... iscs_to_CD
if you are using 1.3.9. The links to the wiki are better if you are using 1.2.5.
-- Bill
